[mapguide-internals] RE: svn checkout/update timeout
Tom Fukushima
tom.fukushima at autodesk.com
Tue May 11 13:19:19 EDT 2010
I created an OSGeo ticket for this a while ago: http://trac.osgeo.org/osgeo/ticket/396
But it was not reproducible.
Jackie, could you info on your situation to it; also any other info that might be useful like H/W, OS, network provider, etc.
Thanks
Tom
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
Sent: Tuesday, May 11, 2010 12:59 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] RE: svn checkout/update timeout
yes, it will resume and usually I have to resume several times, still my
repository copy would be valid
I had this issue from day one of MG repository and on different Windows OS (
XP and 7 , 32 an 64). I didn't have feeling that it is related to OS or
servers overload.
My first impression was that there is some bandwidth limit on
server/repository but I assume if that would be true then we would see more
of those types of complains.
Haris
On Tue, May 11, 2010 at 3:14 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> it will resume, do a svn cleanup if you get errors
> On 11 May 2010 11:03, Jackie Ng <jumpinjackie at gmail.com> wrote:
> > Hi Haris,
> > Does svn resume from the point of failure? I get the impression it
> doesn't.
> > Like I said before, svn update will die at around the 14-15mb mark, so
> > unless there's a 100+mb file in Oem I would've thought repeated attempts
> > would have powered through.
> > - Jackie
> > View this message in context:
> http://osgeo-org.1803224.n2.nabble.com/svn-checkout-update-timeout-tp5029643p5033874.html
> > Sent from the MapGuide Internals mailing list archive at Nabble.com.
> > mapguide-internals mailing list
> > mapguide-internals at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
More information about the mapguide-internals
