[mapguide-internals] Fusion version for MapGuide 2.2 Beta
Trevor Wekel trevor_wekel at otxsystems.com
Tue May 18 19:10:39 EDT 2010
Hi everyone,
We are currently using Fusion trunk for the MapGuide 2.2 Beta.  Should we be using a different branch?
On a Fusion related note, it looks as though tiled maps do not seem to work on fusion/branches/fusion-2.0 or fusion/trunk.  I suspect the same may be true for sandbox/adsk/2.2gp.  A two line fix in MapGuide.js seems to correct the issue
   parseMapLayersAndGroups: function(o) {
        for (var i=0; i<o.layers.length; i++) {
            var layer = new Fusion.Layers.Layer(o.layers[i], this);
            if (layer.isBaseMapLayer) {
                this.bSingleTile = false;
Regards,
Trevor
More information about the mapguide-internals mailing list
