[mapguide-internals] Some questions about mapguide sessions
    Trevor Wekel
    trevor_wekel at otxsystems.com
    Fri Nov 19 12:29:23 EST 2010
Hi Gabriele,
I think it is a bug with the build process.  I suspect we are not stamping the Linux binaries with the build number.  I will look into it.  Please add a defect in Trac.
Regards,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Gabriele Monfardini
Sent: November 19, 2010 2:35 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] Some questions about mapguide sessions
Hi Trevor,
I'm indeed not getting the full build number.
This is the PHP version of your pseudo code snippet (it could be
useful to other reader)
<?php
        require_once('../mapviewerphp/constants.php');
        require_once('../mapviewerphp/layerdefinitionfactory.php');
        $admin = new MgServerAdmin();
        $userInfo = new MgUserInformation($username,$password);
        $admin->Open("127.0.0.1", $userInfo);
        $version = $admin->GetSiteVersion();
        $admin->Close();
        echo $version;
I obtain the string  "2.2.0.0".
Exactly the same result that I obtain from "Web Tier Tests" > "Site" >
"GetSiteVersion" (the official API?)
Should I open a bug?
> For the crashes on Linux, can you try running the MapGuide 2.2 RC1 build
> from a command shell using mgserver.sh with the following setting in serverconfig.ini?
> This may provide some call stack information on the crash if it is memory related:
> [GeneralProperties]
> LinuxMemDebug = 1
Great.
I'll try it and report it back the results, if any
Regards,
Gabriele
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
