[mapguide-internals] PATCH: Ticket 1463 "Access to the CsMap coordinate system dictionary files is not correctly protected by the Mg API"
Andre Barth Andre.Barth at autodesk.com
Mon Oct 18 03:26:19 EDT 2010
Hi all,
could you please have a look at ticket http://trac.osgeo.org/mapguide/ticket/1463 and the patch attached to it?
It's about fixing a bug in the Mg CS API where the calls to the CsMap API aren't correctly protected by the [CriticalClass] variable as currently implemented in CriticalSection.h. Basically, the patch moves the implementation of the [CustomCriticalSection] class in its own Cpp file and declares the references to the [CriticalClass] variable in CriticalSection.h extern.
Thanks,
André
More information about the mapguide-internals mailing list
