[mapguide-internals] PATCH: Ticket 1463 "Access to the CsMap
	coordinate system dictionary files is not correctly protected by the Mg
	API"
    Bruce Dechant
    bruce.dechant at autodesk.com
    Tue Oct 19 12:21:34 EDT 2010
André,
Thanks for creating a patch for this issue.
I'll review it and submit it on your behalf.
Thanks,
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Andre Barth
Sent: Monday, October 18, 2010 1:26 AM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] PATCH: Ticket 1463 "Access to the CsMap coordinate system dictionary files is not correctly protected by the Mg API"
Hi all,
could you please have a look at ticket http://trac.osgeo.org/mapguide/ticket/1463 and the patch attached to it?
It's about fixing a bug in the Mg CS API where the calls to the CsMap API aren't correctly protected by the [CriticalClass] variable as currently implemented in CriticalSection.h. Basically, the patch moves the implementation of the [CustomCriticalSection] class in its own Cpp file and declares the references to the [CriticalClass] variable in CriticalSection.h extern.
Thanks,
André
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
