[mapguide-internals] PATCH: Ticket 1493 "Resize window caused dynamic layers disappear if the map with Base layers in Chrome/Safari"
Ted Yang ted.yang at autodesk.com
Fri Oct 22 05:44:33 EDT 2010
Hi all,
Would you please help to review ticket: https://trac.osgeo.org/mapguide/ticket/1493 and the patch attached to it?
It's about fixing a bug in ajaxviewer that when a map with base layer and dynamic layer works incorrect in Chrome/Safari.
When resize the window, the image for the dynamic layers will be invisible.
The solution is to find the place where should make the map image layer visible.
Best Wishes,
Ted Yang (Yuanyuan Yang)
Reeses,Tel: (8621)3866-4595
More information about the mapguide-internals mailing list
