[mapguide-internals] Re: Plus sign (+) in the middle of the ID
Crispin_at_1Spatial
crispin.hoult at 1spatial.com
Fri Sep 3 03:04:50 EDT 2010
My misunderstaning I think.
When you say you have "trouble with the selection of elements" I thought
that you meant the *getting* of the ID from user-selected elements.
What I now think you mean is that your application is *setting* the MG
Selection set from your of known IDs - and when the encoded ID occasionally
happens to have a '+' in the string the object does not select on the map?
Can you confirm...
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Plus-sign-in-the-middle-of-the-ID-tp5380639p5494248.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
