[mapguide-internals] MapGuide 2.2 RC1 build in two weeks
Trevor Wekel
trevor_wekel at otxsystems.com
Fri Sep 10 13:57:57 EDT 2010
Hi Mike,
You're probably going to hate me... Paul let me create the Fusion 2.2 branch a couple of months ago so that I could get an interim build out the door for MapGuide.
http://trac.osgeo.org/fusion/log/branches/fusion-2.2
Is there anything we need to port from trunk? I suppose we could delete the branch and recreate it from trunk but I'm not sure the new QuickPlot feature is supposed to go into 2.2. That's a MapGuide 2.3 feature.
Regards,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Mike Adair
Sent: September 10, 2010 11:48 AM
To: mapguide-internals at lists.osgeo.org
Subject: Re: [mapguide-internals] MapGuide 2.2 RC1 build in two weeks
Trevor,
FYI, I'll be creating a Fusion v2.2 branch from trunk either later today
or early next week that can be used for this release of MGOS.
Mike
On 9/10/2010 12:26 PM, Trevor Wekel wrote:
> Hi everyone,
> I am going to do some work on the MapGuide 2.2 RC1 build over the next couple of weeks with the target of releasing the MapGuide 2.2 RC1 build by September 24th. In my opinion, these are the critical items holding up the build:
> 1. FDO 3.5 RC2(?) build
> 2. The entire Java Web Extensions API leaks objects (mapguide-internals discussion)
> 3. http://trac.osgeo.org/mapguide/ticket/1423 Linux std::string not thread safe
> 4. http://trac.osgeo.org/mapguide/ticket/1382 Undefined symbols in FDO PostGIS e FDO PostgreSQL/PostGIS providers
> 5. Upgrade 32 bit installer binaries to Apache 2.2.15 (currently 2.2.11)
> 6. Upgrade 32 bit and 64 bit installer binaries to PHP 5.3.3 (assuming VC9 thread-safe binaries are available)
> Is there anything else we need to put into the RC1 build? I will concentrate my efforts on items 1 to 4 and could use some help with the last two.
> Thanks!
> Trevor
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Michael Adair
Senior Software Architect
DM Solutions Group Inc.
Office: (613) 565-5056 x26
madair at dmsolutions.ca
http://www.dmsolutions.ca
http://research.dmsolutions.ca
More information about the mapguide-internals
