[mapguide-internals] Motion Vote: RFC 119 - Enhance URL information in vector layer definition
Sam Wang Sam.Wang at autodesk.com
Tue Aug 2 23:37:36 EDT 2011
Hi Zac,
Existing layer definition will remove original url field, and replace it with a urlData field(complex type with four fields) as described in the RFC and backward compatibility will be kept. So there is no duplicated fields.
And also I think  tooltip is not  the same as "Url Description",  tooltip for a feature can be something entirely unrelated to the URL assigned to the feature.
Thanks,
Sam
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Wednesday, August 03, 2011 11:06 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] Re: Motion Vote: RFC 119 - Enhance URL information in vector layer definition
Thanks Sam,
that makes more sense now, given that this would be in part duplicating the existing tooltip and url fields, wouldn't it be simpler to just add tooltipOverride and urlOverride, i.e still use the existing fields ?
z
On Wed, Aug 3, 2011 at 12:41 PM, Sam Wang <Sam.Wang at autodesk.com> wrote:
> Hi Zac,
> I added a sample definition XML and explains how it should work.
> Thanks,
> Sam
> Spitzer
> Sent: Wednesday, August 03, 2011 9:44 AM
> -1 Zac
> RFC ought to include an example usage of the the new functionality, to solve the problem described in the Motivation section.
> i.e. a sample of what a new layer definition XML would look like, once a clear example is provided and I can understand it, I am happy to review my vote.
> z
> On Wed, Aug 3, 2011 at 10:29 AM, Jackie Ng <jumpinjackie at gmail.com> wrote:
>> +0 Jackie
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/Motion-Vote-RFC-119-Enhance-UR
>> L -information-in-vector-layer-definition-tp6645313p6647008.html
>> Sent from the MapGuide Internals mailing list archive at Nabble.com.
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
Zac Spitzer
+61 405 847 168
More information about the mapguide-internals mailing list
