[mapguide-internals] additional http methods to support Ajax
clients RFC
Zac Spitzer
zac.spitzer at gmail.com
Tue Jan 4 04:43:04 EST 2011
I'd like to put together a RFC of improvements for supporting
javascript clients
without using the API, only via HTTP
before putting the RFC together, I would like to know what people feel is needed
my goal is a extension to the openlayers mapguide support to allow
near automatic
registration of a mapguide layer with simply server, map name and if
required credentials
So I propose a new http method which returns a json/xml set of parameters
which are required to initialise a map
to initialise a mapguide layer with openlayers the following
extents
min scale/ max scale / fixed scales
tiled / untiled
metersPerUnit
projection
tilesize
is this information cached as these requests might hit the server often?
if this information was written into the tile cache as a json file, it would
be great for supporting static tile caches
z
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
