[mapguide-internals] Re: WMS Benchmarking 2011
Daniel Morissette dmorissette at mapgears.com
Wed Jan 12 17:25:19 EST 2011
Jason Birch wrote:
> Do you know if this is likely to be a more organized effort this year?
>  Last year I wasn't able to free up time to participate, but it seemed
> like a bit of a mad scramble trying to get things done with data
> issues, specifications changes, etc. If it's likely to be like that
> again I don't think I can afford the kind of effort required for
> successful outcome.
Hi Jason,
First of all I'm very happy to hear that there is at least a bit of
interest. Your question is a tough one to answer with a simple yes or no.
Short answer is that yes the data is likely to change again this year to
be US-based, and yes we should expect some surprises for some/all
teams... otherwise where would the fun be?
Some of what you allude to with respect to data issues was part of the
game. For instance, most teams had to fix their software to support
shapefiles larger than 2GB... that's a positive outcome of the game and
not a problem with the process if you ask me. With respect to styling:
some of the requirements (labeling very dense contours) forced some of
the teams to improve their labeling for instance... once again that's
part of the game and benefits to the users in the end.
You should keep in mind that participants are always free to run only a
subset of the tests based on the time and effort they are able to put in
and everybody will respect that. We'd love to see you join, even if you
run only a subset of the tests... and hopefully other MapGuide users and
dev will join you and support your efforts, you will uncover and solve
some issues in the software (like most teams do every year) and the
software and its users will win in the end.
I have CC'd the benchmarking list and would suggest that we continue the
discussion there since others may be able to share their own experience
to help you make your decision.
Daniel
Daniel Morissette
http://www.mapgears.com/
More information about the mapguide-internals mailing list
