[mapguide-internals] RE: MapGuide 2.2 RC2
Trevor Wekel trevor_wekel at otxsystems.com
Thu Jan 27 15:15:24 EST 2011
Hi Martin,
I can check in the fix for 1584 and post a new build in a couple of days assuming we do not want to wait and fix any other defect fixes.  There are a few other recently logged tickets that we should probably look at:
http://trac.osgeo.org/mapguide/ticket/1586 Incorrect LL84 wkt string existed in MapGuide code
- This is an easy fix
http://trac.osgeo.org/mapguide/ticket/1583 Tile service doesn't work with JPG
- Not good...
http://trac.osgeo.org/mapguide/ticket/1582 Sheybogan Parcels Layer doesn't render
- I have seen the "Fetching a property value did not match the property type" error with other data sets.
http://trac.osgeo.org/mapguide/ticket/1535 Linux It is not possible to obtain full version number
- I may be able to fix this when I do another Linux build.
And 1584 for reference
http://trac.osgeo.org/mapguide/ticket/1584 Feature source create or update locks up server while under load
- Fix is in hand and has been tested
Do any of these issues impact your installation?
Regards,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Martin Morrison
Sent: January 27, 2011 12:17 PM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] RE: MapGuide 2.2 RC2
So what time frame are we talking about here for RC3?
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA  24018
540.345.1410
gis.edsi.com
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
Sent: Thursday, January 27, 2011 12:38 PM
Hi Martin,
I would like to roll an RC3 build with at least a fix for the following defect
I suppose we should go through a more official nomination process for the RC3 build to see if there are other defects that we need to include.  1584 has significant implications on MapGuide Server stability so I believe the RC3 build is warranted.
Regards,
Trevor
Sent: January 26, 2011 8:33 AM
Subject: [mapguide-internals] MapGuide 2.2 RC2
So what is the status of RC2?  After doing some testing, MrSid images pop right up, install was a breeze (Windows 7 64 bit).  Is this going to be the official release?  I don't run non-released software on our production webservers, this would be a big deal to get this out since it is 64 bit.
Martin Morrison
Roanoke, VA  24018
540.345.1410
gis.edsi.com
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
