[mapguide-internals] RE: MapGuide 2.2 RC2
Zac Spitzer
zac.spitzer at gmail.com
Fri Jan 28 05:46:52 EST 2011
the parcels layer issue was invalid, cryptic error messages confusion
The JPEG tile problem was fixed in trunk, which Jackie solved again anyway
and then we found it was fixed in another task
So we are looking good!
It does worry me that we have been branched for a while and some useful
fixes are now delayed till 2.3.
Do we need Rc3 or can we release?
On Jan 28, 2011 10:35 AM, "Zac Spitzer" <zac.spitzer at gmail.com> wrote:
> Both these are blockers, but hopefully are only minor regressions
>> 1583 -> We don't do tiled maps here. We have ample performance without
them.
> But a lot of people do and it's core functionality
>> 1582 -> Sheboygan is just a sample dataset. Is it something with the
dataset or the code?
> The dataset hasn't changed in a long time, Trevor mentioned he has
> seen this with
> other datasets, this needs to be fixed as it will most likely crop up
> for other people.
> I would also like to formally request a backport of this fix to 3.5 FDO
> SHP provider: Allow ':' characters in property name
> http://trac.osgeo.org/fdo/ticket/737
> So a PSC question, how to do we make a formal request?
> z
> On Fri, Jan 28, 2011 at 7:29 AM, Martin Morrison
> <martin.morrison at edsi.com> wrote:
>> 1586 -> Possibly one demo site. Nothing major. But is a minor fix, so
why not?
them.
>> 1535 -> What is Linux? <G>.
>> A couple of days is not going to hurt us. A couple of months might...I
would hate to see the ship schedule slip like last year's did just to keep
adding stuff.
>> Martin Morrison
>> Application Engineer
>> Engineering Design Systems, Inc.
>> 3780 Peters Creek Rd Ext SW
>> Roanoke, VA 24018
>> 540.345.1410
>> gis.edsi.com
>> -----Original Message-----
>> From: mapguide-internals-bounces at lists.osgeo.org [mailto:
mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
>> Sent: Thursday, January 27, 2011 3:15 PM
>> To: MapGuide Internals Mail List
>> Subject: [mapguide-internals] RE: MapGuide 2.2 RC2
>> Hi Martin,
>> I can check in the fix for 1584 and post a new build in a couple of days
assuming we do not want to wait and fix any other defect fixes. There are a
few other recently logged tickets that we should probably look at:
>> http://trac.osgeo.org/mapguide/ticket/1586 Incorrect LL84 wkt string
existed in MapGuide code
>> - This is an easy fix
>> http://trac.osgeo.org/mapguide/ticket/1583 Tile service doesn't work with
JPG
>> - Not good...
>> http://trac.osgeo.org/mapguide/ticket/1582 Sheybogan Parcels Layer
doesn't render
>> - I have seen the "Fetching a property value did not match the property
type" error with other data sets.
>> http://trac.osgeo.org/mapguide/ticket/1535 Linux It is not possible to
obtain full version number
>> - I may be able to fix this when I do another Linux build.
>> And 1584 for reference
>> http://trac.osgeo.org/mapguide/ticket/1584 Feature source create or
update locks up server while under load
>> - Fix is in hand and has been tested
>> Do any of these issues impact your installation?
>> Regards,
>> Trevor
mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Martin Morrison
>> Sent: January 27, 2011 12:17 PM
>> So what time frame are we talking about here for RC3?
>> Martin Morrison
>> Roanoke, VA 24018
>> 540.345.1410
>> gis.edsi.com
>> Sent: Thursday, January 27, 2011 12:38 PM
>> Hi Martin,
>> I would like to roll an RC3 build with at least a fix for the following
defect
>> I suppose we should go through a more official nomination process for the
RC3 build to see if there are other defects that we need to include. 1584
has significant implications on MapGuide Server stability so I believe the
RC3 build is warranted.
>> Regards,
>> Trevor
>> Sent: January 26, 2011 8:33 AM
>> Subject: [mapguide-internals] MapGuide 2.2 RC2
>> So what is the status of RC2? After doing some testing, MrSid images pop
right up, install was a breeze (Windows 7 64 bit). Is this going to be the
official release? I don't run non-released software on our production
webservers, this would be a big deal to get this out since it is 64 bit.
>> Martin Morrison
>> Roanoke, VA 24018
>> 540.345.1410
>> gis.edsi.com
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
More information about the mapguide-internals
