[mapguide-internals] RE: MapGuide 2.2 RC2
Zac Spitzer zac.spitzer at gmail.com
Fri Jan 28 05:50:09 EST 2011
1584 is an improvement and shouldn't block the release.
Uv might be able to have a look into it for the next release.
End of the day, if it's important enough for you, sponsor a dev to fix it.
That's what I have done....
On Jan 28, 2011 9:46 PM, "Zac Spitzer" <zac.spitzer at gmail.com> wrote:
> the parcels layer issue was invalid, cryptic error messages confusion
> The JPEG tile problem was fixed in trunk, which Jackie solved again anyway
> and then we found it was fixed in another task
> So we are looking good!
> It does worry me that we have been branched for a while and some useful
> fixes are now delayed till 2.3.
> Do we need Rc3 or can we release?
> On Jan 28, 2011 10:35 AM, "Zac Spitzer" <zac.spitzer at gmail.com> wrote:
>> Both these are blockers, but hopefully are only minor regressions
>>> 1583 -> We don't do tiled maps here. We have ample performance without
> them.
>> But a lot of people do and it's core functionality
>>> 1582 -> Sheboygan is just a sample dataset. Is it something with the
> dataset or the code?
>> The dataset hasn't changed in a long time, Trevor mentioned he has
>> seen this with
>> other datasets, this needs to be fixed as it will most likely crop up
>> for other people.
>> I would also like to formally request a backport of this fix to 3.5 FDO
>> SHP provider: Allow ':' characters in property name
>> http://trac.osgeo.org/fdo/ticket/737
>> So a PSC question, how to do we make a formal request?
>> z
>> On Fri, Jan 28, 2011 at 7:29 AM, Martin Morrison
>> <martin.morrison at edsi.com> wrote:
>>> 1586 -> Possibly one demo site. Nothing major. But is a minor fix, so
> why not?
> them.
>>> 1535 -> What is Linux? <G>.
>>> A couple of days is not going to hurt us. A couple of months might...I
> would hate to see the ship schedule slip like last year's did just to keep
> adding stuff.
>>> Martin Morrison
>>> Application Engineer
>>> Engineering Design Systems, Inc.
>>> 3780 Peters Creek Rd Ext SW
>>> Roanoke, VA 24018
>>> 540.345.1410
>>> gis.edsi.com
>>> -----Original Message-----
>>> From: mapguide-internals-bounces at lists.osgeo.org [mailto:
> mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
>>> Sent: Thursday, January 27, 2011 3:15 PM
>>> To: MapGuide Internals Mail List
>>> Subject: [mapguide-internals] RE: MapGuide 2.2 RC2
>>> Hi Martin,
>>> I can check in the fix for 1584 and post a new build in a couple of days
> assuming we do not want to wait and fix any other defect fixes. There are
a
> few other recently logged tickets that we should probably look at:
>>> http://trac.osgeo.org/mapguide/ticket/1586 Incorrect LL84 wkt string
> existed in MapGuide code
>>> - This is an easy fix
>>> http://trac.osgeo.org/mapguide/ticket/1583 Tile service doesn't work
with
> JPG
>>> - Not good...
>>> http://trac.osgeo.org/mapguide/ticket/1582 Sheybogan Parcels Layer
> doesn't render
>>> - I have seen the "Fetching a property value did not match the property
> type" error with other data sets.
>>> http://trac.osgeo.org/mapguide/ticket/1535 Linux It is not possible to
> obtain full version number
>>> - I may be able to fix this when I do another Linux build.
>>> And 1584 for reference
>>> http://trac.osgeo.org/mapguide/ticket/1584 Feature source create or
> update locks up server while under load
>>> - Fix is in hand and has been tested
>>> Do any of these issues impact your installation?
>>> Regards,
>>> Trevor
> mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Martin Morrison
>>> Sent: January 27, 2011 12:17 PM
>>> So what time frame are we talking about here for RC3?
>>> Martin Morrison
>>> Roanoke, VA 24018
>>> 540.345.1410
>>> gis.edsi.com
>>> Sent: Thursday, January 27, 2011 12:38 PM
>>> Hi Martin,
>>> I would like to roll an RC3 build with at least a fix for the following
> defect
>>> I suppose we should go through a more official nomination process for
the
> RC3 build to see if there are other defects that we need to include. 1584
> has significant implications on MapGuide Server stability so I believe the
> RC3 build is warranted.
>>> Regards,
>>> Trevor
>>> Sent: January 26, 2011 8:33 AM
>>> Subject: [mapguide-internals] MapGuide 2.2 RC2
>>> So what is the status of RC2? After doing some testing, MrSid images pop
> right up, install was a breeze (Windows 7 64 bit). Is this going to be the
> official release? I don't run non-released software on our production
> webservers, this would be a big deal to get this out since it is 64 bit.
>>> Martin Morrison
>>> Roanoke, VA 24018
>>> 540.345.1410
>>> gis.edsi.com
>>> mapguide-internals mailing list
>>> mapguide-internals at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
>> Zac Spitzer
>> Solution Architect / Director
>> Ennoble Consultancy Australia
>> http://www.ennoble.com.au
>> http://zacster.blogspot.com
>> +61 405 847 168
More information about the mapguide-internals mailing list
