[mapguide-internals] RE: MapGuide 2.2 RC2
Trevor Wekel
trevor_wekel at otxsystems.com
Fri Jan 28 08:03:25 EST 2011
Hi Zac,
I will start up a discussion on fdo-internals regarding the backport of ticket 737 to FDO 3.5.
Regards,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: January 27, 2011 4:35 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] RE: MapGuide 2.2 RC2
Both these are blockers, but hopefully are only minor regressions
> 1583 -> We don't do tiled maps here. We have ample performance without them.
But a lot of people do and it's core functionality
> 1582 -> Sheboygan is just a sample dataset. Is it something with the dataset or the code?
The dataset hasn't changed in a long time, Trevor mentioned he has
seen this with
other datasets, this needs to be fixed as it will most likely crop up
for other people.
I would also like to formally request a backport of this fix to 3.5 FDO
SHP provider: Allow ':' characters in property name
http://trac.osgeo.org/fdo/ticket/737
So a PSC question, how to do we make a formal request?
z
On Fri, Jan 28, 2011 at 7:29 AM, Martin Morrison
<martin.morrison at edsi.com> wrote:
> 1586 -> Possibly one demo site. Nothing major. But is a minor fix, so why not?
> 1535 -> What is Linux? <G>.
> A couple of days is not going to hurt us. A couple of months might...I would hate to see the ship schedule slip like last year's did just to keep adding stuff.
> Martin Morrison
> Application Engineer
> Engineering Design Systems, Inc.
> 3780 Peters Creek Rd Ext SW
> Roanoke, VA 24018
> 540.345.1410
> gis.edsi.com
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
> Sent: Thursday, January 27, 2011 3:15 PM
> Subject: [mapguide-internals] RE: MapGuide 2.2 RC2
> Hi Martin,
> I can check in the fix for 1584 and post a new build in a couple of days assuming we do not want to wait and fix any other defect fixes. There are a few other recently logged tickets that we should probably look at:
> http://trac.osgeo.org/mapguide/ticket/1586 Incorrect LL84 wkt string existed in MapGuide code
> - This is an easy fix
> http://trac.osgeo.org/mapguide/ticket/1583 Tile service doesn't work with JPG
> - Not good...
> http://trac.osgeo.org/mapguide/ticket/1582 Sheybogan Parcels Layer doesn't render
> - I have seen the "Fetching a property value did not match the property type" error with other data sets.
> http://trac.osgeo.org/mapguide/ticket/1535 Linux It is not possible to obtain full version number
> - I may be able to fix this when I do another Linux build.
> And 1584 for reference
> http://trac.osgeo.org/mapguide/ticket/1584 Feature source create or update locks up server while under load
> - Fix is in hand and has been tested
> Do any of these issues impact your installation?
> Regards,
> Trevor
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Martin Morrison
> Sent: January 27, 2011 12:17 PM
> So what time frame are we talking about here for RC3?
> Martin Morrison
> Roanoke, VA 24018
> 540.345.1410
> gis.edsi.com
> Sent: Thursday, January 27, 2011 12:38 PM
> Hi Martin,
> I would like to roll an RC3 build with at least a fix for the following defect
> I suppose we should go through a more official nomination process for the RC3 build to see if there are other defects that we need to include. 1584 has significant implications on MapGuide Server stability so I believe the RC3 build is warranted.
> Regards,
> Trevor
> Sent: January 26, 2011 8:33 AM
> Subject: [mapguide-internals] MapGuide 2.2 RC2
> So what is the status of RC2? After doing some testing, MrSid images pop right up, install was a breeze (Windows 7 64 bit). Is this going to be the official release? I don't run non-released software on our production webservers, this would be a big deal to get this out since it is 64 bit.
> Martin Morrison
> Roanoke, VA 24018
> 540.345.1410
> gis.edsi.com
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
