[mapguide-internals] RE: MapGuide 2.2 RC2
Zac Spitzer
zac.spitzer at gmail.com
Fri Jan 28 22:14:58 EST 2011
my previous comment about 1584 was actually in regards to 1518,
RC3 is looking good!
On Sat, Jan 29, 2011 at 12:49 AM, Martin Morrison
<martin.morrison at edsi.com> wrote:
> So after reading all of the notes over the last day or two I will revise the recap I did...
> 1586 -> Possibly one demo site. Nothing major. But is a minor fix, so why not? (no change, fix is ready)
> 1583 -> Already fixed. (See Jackie's note)
> 1582 -> Whoops...(invalid)
> 1535 -> Linux issue. Nothing new to recap here, is this really a blocker? The way I see it, this only affects developers, not the enduser.
> 1584 -> Already fixed. (See Trevor's note)
> So 4 of the 5 issues are either fixed or invalid. The other (1535) should not stop RC3.
> Martin Morrison
> Application Engineer
> Engineering Design Systems, Inc.
> 3780 Peters Creek Rd Ext SW
> Roanoke, VA 24018
> 540.345.1410
> gis.edsi.com
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
> Sent: Friday, January 28, 2011 7:39 AM
> To: MapGuide Internals Mail List
> Subject: RE: [mapguide-internals] RE: MapGuide 2.2 RC2
> Hi Zac,
> I have already coded a fix for 1584. The patch is attached to the defect.
> Allow me to put some perspective on 1584. Without the fix, simply performing a buffer or measure operation (which creates a temporary SDF) could take you MapGuide Server down.
> Bruce has already reviewed the patch and I will check it into MapGuide 2.2 and trunk today or tomorrow.
> Regards,
> Trevor
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: January 28, 2011 3:50 AM
> Subject: Re: [mapguide-internals] RE: MapGuide 2.2 RC2
> 1584 is an improvement and shouldn't block the release.
> Uv might be able to have a look into it for the next release.
> End of the day, if it's important enough for you, sponsor a dev to fix it.
> That's what I have done....
> On Jan 28, 2011 9:46 PM, "Zac Spitzer" <zac.spitzer at gmail.com> wrote:
>> the parcels layer issue was invalid, cryptic error messages confusion
>> The JPEG tile problem was fixed in trunk, which Jackie solved again
>> anyway and then we found it was fixed in another task
>> So we are looking good!
>> It does worry me that we have been branched for a while and some
>> useful fixes are now delayed till 2.3.
>> Do we need Rc3 or can we release?
>> On Jan 28, 2011 10:35 AM, "Zac Spitzer" <zac.spitzer at gmail.com> wrote:
>>> Both these are blockers, but hopefully are only minor regressions
>>>> 1583 -> We don't do tiled maps here. We have ample performance
>>>> without
>> them.
>>> But a lot of people do and it's core functionality
>>>> 1582 -> Sheboygan is just a sample dataset. Is it something with the
>> dataset or the code?
>>> The dataset hasn't changed in a long time, Trevor mentioned he has
>>> seen this with other datasets, this needs to be fixed as it will most
>>> likely crop up for other people.
>>> I would also like to formally request a backport of this fix to 3.5
>>> FDO
>>> SHP provider: Allow ':' characters in property name
>>> http://trac.osgeo.org/fdo/ticket/737
>>> So a PSC question, how to do we make a formal request?
>>> z
>>> On Fri, Jan 28, 2011 at 7:29 AM, Martin Morrison
>>>> so
>> why not?
>>>> without
>> them.
>>>> 1535 -> What is Linux? <G>.
>>>> A couple of days is not going to hurt us. A couple of months
>>>> might...I
>> would hate to see the ship schedule slip like last year's did just to
>> keep adding stuff.
>>>> Martin Morrison
>>>> Roanoke, VA 24018
>>>> 540.345.1410
>>>> gis.edsi.com
>>>> Sent: Thursday, January 27, 2011 3:15 PM
>>>> Subject: [mapguide-internals] RE: MapGuide 2.2 RC2
>>>> Hi Martin,
>>>> I can check in the fix for 1584 and post a new build in a couple of
>>>> days
>> assuming we do not want to wait and fix any other defect fixes. There
>> are
> a
>> few other recently logged tickets that we should probably look at:
>>>> http://trac.osgeo.org/mapguide/ticket/1586 Incorrect LL84 wkt string
>> existed in MapGuide code
>>>> - This is an easy fix
>>>> http://trac.osgeo.org/mapguide/ticket/1583 Tile service doesn't work
> with
>> JPG
>>>> - Not good...
>>>> http://trac.osgeo.org/mapguide/ticket/1582 Sheybogan Parcels Layer
>> doesn't render
>>>> - I have seen the "Fetching a property value did not match the
>>>> property
>> type" error with other data sets.
>>>> http://trac.osgeo.org/mapguide/ticket/1535 Linux It is not possible
>>>> to
>> obtain full version number
>>>> - I may be able to fix this when I do another Linux build.
>>>> And 1584 for reference
>>>> http://trac.osgeo.org/mapguide/ticket/1584 Feature source create or
>> update locks up server while under load
>>>> - Fix is in hand and has been tested
>>>> Do any of these issues impact your installation?
>>>> Regards,
>>>> Trevor
>> mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Martin
>> Morrison
>>>> Sent: January 27, 2011 12:17 PM
>>>> So what time frame are we talking about here for RC3?
>>>> Martin Morrison
>>>> Roanoke, VA 24018
>>>> 540.345.1410
>>>> gis.edsi.com
>>>> Sent: Thursday, January 27, 2011 12:38 PM
>>>> Hi Martin,
>>>> I would like to roll an RC3 build with at least a fix for the
>>>> following
>> defect
>>>> I suppose we should go through a more official nomination process
>>>> for
> the
>> RC3 build to see if there are other defects that we need to include.
>> 1584 has significant implications on MapGuide Server stability so I
>> believe the
>> RC3 build is warranted.
>>>> Regards,
>>>> Trevor
>> Morrison
>>>> Sent: January 26, 2011 8:33 AM
>>>> Subject: [mapguide-internals] MapGuide 2.2 RC2
>>>> So what is the status of RC2? After doing some testing, MrSid images
>>>> pop
>> right up, install was a breeze (Windows 7 64 bit). Is this going to be
>> the official release? I don't run non-released software on our
>> production webservers, this would be a big deal to get this out since it is 64 bit.
>>>> Martin Morrison
>>>> Roanoke, VA 24018
>>>> 540.345.1410
>>>> gis.edsi.com
>>>> _______________________________________________
>>>> mapguide-internals mailing list
>>>> mapguide-internals at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
>>> Zac Spitzer
>>> Solution Architect / Director
>>> Ennoble Consultancy Australia
>>> http://www.ennoble.com.au
>>> http://zacster.blogspot.com
>>> +61 405 847 168
Zac Spitzer
+61 405 847 168
More information about the mapguide-internals
