[mapguide-internals] RE: MapGuide 2.2 RC2
Martin Morrison
martin.morrison at edsi.com
Fri Jan 28 08:49:06 EST 2011
So after reading all of the notes over the last day or two I will revise the recap I did...
1586 -> Possibly one demo site. Nothing major. But is a minor fix, so why not? (no change, fix is ready)
1583 -> Already fixed. (See Jackie's note)
1582 -> Whoops...(invalid)
1535 -> Linux issue. Nothing new to recap here, is this really a blocker? The way I see it, this only affects developers, not the enduser.
1584 -> Already fixed. (See Trevor's note)
So 4 of the 5 issues are either fixed or invalid. The other (1535) should not stop RC3.
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA 24018
540.345.1410
gis.edsi.com
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
Sent: Friday, January 28, 2011 7:39 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] RE: MapGuide 2.2 RC2
Hi Zac,
I have already coded a fix for 1584. The patch is attached to the defect.
Allow me to put some perspective on 1584. Without the fix, simply performing a buffer or measure operation (which creates a temporary SDF) could take you MapGuide Server down.
Bruce has already reviewed the patch and I will check it into MapGuide 2.2 and trunk today or tomorrow.
Regards,
Trevor
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: January 28, 2011 3:50 AM
Subject: Re: [mapguide-internals] RE: MapGuide 2.2 RC2
1584 is an improvement and shouldn't block the release.
Uv might be able to have a look into it for the next release.
End of the day, if it's important enough for you, sponsor a dev to fix it.
That's what I have done....
On Jan 28, 2011 9:46 PM, "Zac Spitzer" <zac.spitzer at gmail.com> wrote:
> the parcels layer issue was invalid, cryptic error messages confusion
> The JPEG tile problem was fixed in trunk, which Jackie solved again
> anyway and then we found it was fixed in another task
> So we are looking good!
> It does worry me that we have been branched for a while and some
> useful fixes are now delayed till 2.3.
> Do we need Rc3 or can we release?
> On Jan 28, 2011 10:35 AM, "Zac Spitzer" <zac.spitzer at gmail.com> wrote:
>> Both these are blockers, but hopefully are only minor regressions
>>> 1583 -> We don't do tiled maps here. We have ample performance
>>> without
> them.
>> But a lot of people do and it's core functionality
>>> 1582 -> Sheboygan is just a sample dataset. Is it something with the
> dataset or the code?
>> The dataset hasn't changed in a long time, Trevor mentioned he has
>> seen this with other datasets, this needs to be fixed as it will most
>> likely crop up for other people.
>> I would also like to formally request a backport of this fix to 3.5
>> FDO
>> SHP provider: Allow ':' characters in property name
>> http://trac.osgeo.org/fdo/ticket/737
>> So a PSC question, how to do we make a formal request?
>> z
>> On Fri, Jan 28, 2011 at 7:29 AM, Martin Morrison
>>> so
> why not?
>>> without
> them.
>>> 1535 -> What is Linux? <G>.
>>> A couple of days is not going to hurt us. A couple of months
>>> might...I
> would hate to see the ship schedule slip like last year's did just to
> keep adding stuff.
>>> Martin Morrison
>>> Roanoke, VA 24018
>>> 540.345.1410
>>> gis.edsi.com
>>> Sent: Thursday, January 27, 2011 3:15 PM
>>> Subject: [mapguide-internals] RE: MapGuide 2.2 RC2
>>> Hi Martin,
>>> I can check in the fix for 1584 and post a new build in a couple of
>>> days
> assuming we do not want to wait and fix any other defect fixes. There
> are
a
> few other recently logged tickets that we should probably look at:
>>> http://trac.osgeo.org/mapguide/ticket/1586 Incorrect LL84 wkt string
> existed in MapGuide code
>>> - This is an easy fix
>>> http://trac.osgeo.org/mapguide/ticket/1583 Tile service doesn't work
with
> JPG
>>> - Not good...
>>> http://trac.osgeo.org/mapguide/ticket/1582 Sheybogan Parcels Layer
> doesn't render
>>> - I have seen the "Fetching a property value did not match the
>>> property
> type" error with other data sets.
>>> http://trac.osgeo.org/mapguide/ticket/1535 Linux It is not possible
>>> to
> obtain full version number
>>> - I may be able to fix this when I do another Linux build.
>>> And 1584 for reference
>>> http://trac.osgeo.org/mapguide/ticket/1584 Feature source create or
> update locks up server while under load
>>> - Fix is in hand and has been tested
>>> Do any of these issues impact your installation?
>>> Regards,
>>> Trevor
> mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Martin
> Morrison
>>> Sent: January 27, 2011 12:17 PM
>>> So what time frame are we talking about here for RC3?
>>> Martin Morrison
>>> Roanoke, VA 24018
>>> 540.345.1410
>>> gis.edsi.com
>>> Sent: Thursday, January 27, 2011 12:38 PM
>>> Hi Martin,
>>> I would like to roll an RC3 build with at least a fix for the
>>> following
> defect
>>> I suppose we should go through a more official nomination process
>>> for
the
> RC3 build to see if there are other defects that we need to include.
> 1584 has significant implications on MapGuide Server stability so I
> believe the
> RC3 build is warranted.
>>> Regards,
>>> Trevor
> Morrison
>>> Sent: January 26, 2011 8:33 AM
>>> Subject: [mapguide-internals] MapGuide 2.2 RC2
>>> So what is the status of RC2? After doing some testing, MrSid images
>>> pop
> right up, install was a breeze (Windows 7 64 bit). Is this going to be
> the official release? I don't run non-released software on our
> production webservers, this would be a big deal to get this out since it is 64 bit.
>>> Martin Morrison
>>> Roanoke, VA 24018
>>> 540.345.1410
>>> gis.edsi.com
>>> mapguide-internals mailing list
>>> mapguide-internals at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
>> Zac Spitzer
>> Solution Architect / Director
>> Ennoble Consultancy Australia
>> http://www.ennoble.com.au
>> http://zacster.blogspot.com
>> +61 405 847 168
More information about the mapguide-internals
