[mapguide-internals] Re: When do we need tooltips in MapGuide?
Michael Adair
madair at dmsolutions.ca
Wed Jul 6 13:29:59 EDT 2011
Fusion already supports a "Delay" parameter which represents the time
the mouse has to be still before a MapTip will appear, defaults to 350ms
but can also be set in the AppDef MapTip widget extension element.
Mike
On 06/07/2011 1:11 PM, andrewd wrote:
> As a user who very often uses tooltips, I would hate to have to apply a patch
> or edit files to allow them to be enabled, if that's what's being tossed
> around. I also would need them on no matter what tool is selected, for my
> purposes. I would make the suggestion that you let Maestro handle this - why
> not add something to a map definition or weblayout/fusion app that lets you
> enable/disable tooltips? Then you can use Maestro to configure things
> (allowing all users to easily enable/disable), and you could set Maestro up
> to disable them by default when making one of those types of objects (which
> would accomplish the same goal that you're looking for).
> Actually, as I'm writing, I've thought of another question - why should
> "QueryMapFeatures" be called every time you move the cursor? Shouldn't it
> only be called when your cursor has just been moved and is now still?
> Tooltips don't appear until you hover anyway, so why would you need to query
> the tooltip data while you're still moving the cursor?
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/When-do-we-need-tooltips-in-MapGuide-tp6549085p6555236.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
