[mapguide-internals] RE: Motion: Commit rights for Mars Wu and
Spark Liu
Walt Welton-Lair
walt.welton-lair at autodesk.com
Thu Jul 28 13:19:45 EDT 2011
As long as they have read and understood the coding standards (https://trac.osgeo.org/mapguide/wiki/MapGuideCodingStandards) then I support this.
Walt
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Bruce Dechant
Sent: Thursday, July 28, 2011 11:56 AM
To: MapGuide Internals Mail List (mapguide-internals at lists.osgeo.org)
Subject: [mapguide-internals] Motion: Commit rights for Mars Wu and Spark Liu
Hi All,
I'd like to propose that we grant subversion commit rights for the MapGuide vault to Mars Wu and Spark Liu.
They are Autodesk developers working in Shanghai, and have made numerous defect fixes and enhancements to the code base over the last few years.
Mars Wu has worked on MGOS for more than 2 years. Here is a summary of the tickets, changesets and RFC he has done:
RFC:
- MapGuide RFC 96 - QuickPlot solution for both Ajax and Fusion viewers<http://trac.osgeo.org/mapguide/wiki/MapGuideRfc96>
Tickets:
- #1412<http://trac.osgeo.org/mapguide/ticket/1412> Implement RFC 96 - Quick Plot solution for fusion<http://trac.osgeo.org/mapguide/ticket/1412>
- #1414<http://trac.osgeo.org/mapguide/ticket/1414> Implement RFC 96 - Quick Plot solution for ajax<http://trac.osgeo.org/mapguide/ticket/1414>
- #1435<http://trac.osgeo.org/mapguide/ticket/1435> IE8: Map context menu doesn't work after Quick Plot is invoked<http://trac.osgeo.org/mapguide/ticket/1435>
- #1443<http://trac.osgeo.org/mapguide/ticket/1443> MgProxyFeatureService::GetCapabilities is using a fixed api version 1.0.0<http://trac.osgeo.org/mapguide/ticket/1443>
- #1589<http://trac.osgeo.org/mapguide/ticket/1589> Ajax Quick Plot: Capture box cannot move or rotate when base layers exist<http://trac.osgeo.org/mapguide/ticket/1589>
- #1757<http://trac.osgeo.org/mapguide/ticket/1757> Quick Ploat cannot generate map picture in some non-English locale<http://trac.osgeo.org/mapguide/ticket/1757>
- #1521<http://trac.osgeo.org/mapguide/ticket/1521> Use mouse wheel to zoom map in the "Digitize" process<http://trac.osgeo.org/mapguide/ticket/1521>
- #1539<http://trac.osgeo.org/mapguide/ticket/1539> Script error when closing IE window / tab with the Quick Plot preview dialog open in Ajax viewer<http://trac.osgeo.org/mapguide/ticket/1539>
- #1546<http://trac.osgeo.org/mapguide/ticket/1546> Ajax quick plot enhancements: mouse cursor and event controlling<http://trac.osgeo.org/mapguide/ticket/1546>
- #1585<http://trac.osgeo.org/mapguide/ticket/1585> Zoom Rectange doesn't work properly in Ajax viewer<http://trac.osgeo.org/mapguide/ticket/1585>
Changesets:
- 6012<http://trac.osgeo.org/mapguide/changeset/6012>
- 6010<http://trac.osgeo.org/mapguide/changeset/6010>
- 5509<http://trac.osgeo.org/mapguide/changeset/5509>
- 5507<http://trac.osgeo.org/mapguide/changeset/5507>
- 5501<http://trac.osgeo.org/mapguide/changeset/5501>
- 5430<http://trac.osgeo.org/mapguide/changeset/5430>
- 5512<http://trac.osgeo.org/mapguide/changeset/5512>
- 5411<http://trac.osgeo.org/mapguide/changeset/5411>
- 5394<http://trac.osgeo.org/mapguide/changeset/5394>
- 5152<http://trac.osgeo.org/mapguide/changeset/5152>
- 5132<http://trac.osgeo.org/mapguide/changeset/5132>
- 5098<http://trac.osgeo.org/mapguide/changeset/5098>
- 5097<http://trac.osgeo.org/mapguide/changeset/5097>
- 5095<http://trac.osgeo.org/mapguide/changeset/5095>
- 4091<http://trac.osgeo.org/mapguide/changeset/4091>
Spark has worked on MGOS for more than 2 years. Here is a summary of the tickets, changesets and RFC he has done:
RFC:
- 108 Support Watermark<http://trac.osgeo.org/mapguide/wiki/MapGuideRfc108>
Tickets:
- 1514 Ctrl+Click can't end digitize LineString in Chrome on Windows<http://trac.osgeo.org/mapguide/ticket/1514>
- 1527 Rendering fails if the map references to a not-exist resource<http://trac.osgeo.org/mapguide/ticket/1527>
- 1553 Ctrl+Click at first when "selecting polygon" shows error message in Safari / Chrome<http://trac.osgeo.org/mapguide/ticket/1553>
- 1605 There is no Serializable attribute for C# wrapper of any exception class which make the exception can't get across the AppDomain<http://trac.osgeo.org/mapguide/ticket/1605>
- 1728 Fetch size is not set when using command even when DataCacheSize configuration is set<http://trac.osgeo.org/mapguide/ticket/1728>
- 1752 Misuse column name instead of column index during data reader's serialization<http://trac.osgeo.org/mapguide/ticket/1752>
- 1756 ServerFeatureService.DescribeSchemaAsXml will throw exception when geometry property is inherited from base class<http://trac.osgeo.org/mapguide/ticket/1756>
- 1762 Connect always shows "Cannot parse XML document whose stream is at end-of-file." when setting configuration<http://trac.osgeo.org/mapguide/ticket/1762>
Changesets:
- 6011<http://trac.osgeo.org/mapguide/changeset/6011>
- 5999<http://trac.osgeo.org/mapguide/changeset/5999>
- 5988<http://trac.osgeo.org/mapguide/changeset/5988>
- 5949<http://trac.osgeo.org/mapguide/changeset/5949>
- 5557<http://trac.osgeo.org/mapguide/changeset/5557>
- 5556<http://trac.osgeo.org/mapguide/changeset/5556>
- 5458<http://trac.osgeo.org/mapguide/changeset/5458>
- 5444<http://trac.osgeo.org/mapguide/changeset/5444>
- 5393<http://trac.osgeo.org/mapguide/changeset/5393>
- 5367<http://trac.osgeo.org/mapguide/changeset/5367>
- 5366<http://trac.osgeo.org/mapguide/changeset/5366>
- 5365<http://trac.osgeo.org/mapguide/changeset/5365>
- 5302<http://trac.osgeo.org/mapguide/changeset/5302>
- 5290<http://trac.osgeo.org/mapguide/changeset/5290>
- 5237<http://trac.osgeo.org/mapguide/changeset/5237>
- 5220<http://trac.osgeo.org/mapguide/changeset/5220>
- 5168<http://trac.osgeo.org/mapguide/changeset/5168>
- 5139<http://trac.osgeo.org/mapguide/changeset/5139>
- 4461<http://trac.osgeo.org/mapguide/changeset/4461>
I would like to motion for a vote on giving Mars Wu and Spark Liu commit rights to the MapGuide vault.
+1 Bruce
Thanks,
Bruce
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
