[mapguide-internals] Small Change to RFC 118
Mars Wu
mars.wu at autodesk.com
Fri Jul 29 09:26:18 EDT 2011
Hi all,
Thank you very much for the vote!
And I made a small change to this RFC by adding following content:
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc118
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc118?action=diff&version=12&old_version=11
And to make the generated map image have the correct background color, another MgMapBase? method needs be exposed as Web API to get the map's background color:
STRING MgMapBase::GetBackgroundColor()
Sorry that I changed the RFC after votes. Please respond if you have negative feedback to this change.
Thanks,
Mars
More information about the mapguide-internals
