[mapguide-internals] RE: Small Change to RFC 118
Bruce Dechant bruce.dechant at autodesk.com
Fri Jul 29 11:19:56 EDT 2011
Mars,
Add this change to a new section at the end called "Addendum" and leave the rest of the RFC as it originally was. That way the change is easy to identify.
I'm fine with the change.
Thanks,
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Mars Wu
Sent: Friday, July 29, 2011 7:26 AM
To: MapGuide Internals Mail List (mapguide-internals at lists.osgeo.org)
Subject: [mapguide-internals] Small Change to RFC 118
Hi all,
Thank you very much for the vote!
And I made a small change to this RFC by adding following content:
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc118
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc118?action=diff&version=12&old_version=11
And to make the generated map image have the correct background color, another MgMapBase? method needs be exposed as Web API to get the map's background color:
STRING MgMapBase::GetBackgroundColor()
Sorry that I changed the RFC after votes. Please respond if you have negative feedback to this change.
Thanks,
Mars
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
