[mapguide-internals] RE: Small Change to RFC 118
Mars Wu
mars.wu at autodesk.com
Sun Jul 31 21:46:30 EDT 2011
Hi Bruce,
Thank you very much for the comments. I moved the additional content to the section of "Addendum" and kept the original content unchanged.
Thanks,
Mars
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Bruce Dechant
Sent: Friday, July 29, 2011 11:20 PM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] RE: Small Change to RFC 118
Mars,
Add this change to a new section at the end called "Addendum" and leave the rest of the RFC as it originally was. That way the change is easy to identify.
I'm fine with the change.
Thanks,
Bruce
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Mars Wu
Sent: Friday, July 29, 2011 7:26 AM
To: MapGuide Internals Mail List (mapguide-internals at lists.osgeo.org)
Subject: [mapguide-internals] Small Change to RFC 118
Hi all,
Thank you very much for the vote!
And I made a small change to this RFC by adding following content:
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc118
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc118?action=diff&version=12&old_version=11
And to make the generated map image have the correct background color, another MgMapBase? method needs be exposed as Web API to get the map's background color:
STRING MgMapBase::GetBackgroundColor()
Sorry that I changed the RFC after votes. Please respond if you have negative feedback to this change.
Thanks,
Mars
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
