[mapguide-internals] Mapguide 2.2.1 release roadmap
Martin Morrison martin.morrison at edsi.com
Wed Jun 1 08:30:38 EDT 2011
I have no objection to leaving the IIS side alone.
However on the Apache side we aren't compressing everything possible.  CSS for example.  It is not a huge change, but why not?  Every little bit helps.
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA  24018
540.345.1410
gis.edsi.com
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Wednesday, June 01, 2011 3:42 AM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] Mapguide 2.2.1 release roadmap
I agree with Jason, leave IIS up to the admins to tweak,
it's a nightmare of complexity with all the versions to get right.
Anyone up for writing a wiki page with some links for doing
this with IIS?
z
On Wed, Jun 1, 2011 at 9:14 AM, Jason Birch <jason at jasonbirch.com> wrote:
> This is something that can be configured at the webserver level for
> both IIS and Apache. I think I saw Jackie check in the necessary
> changes for Apache.
> IMO for IIS this should be up to the site admin to set up as a config
> best practice (along with setting up long caching for images/css/js)
> unless someone is brave enough to step up and figure out what to do
> about the complexity of enabling/installing modules, adding compressed
> content types, etc on IIS via scripting.  Apache is "easy" because we
> control the entire install. IIS is a pain in the ass because of the
> number of potential configuration states.
> Jason
> On 2011-05-31, Martin Morrison <martin.morrison at edsi.com> wrote:
>> On the gzip ticket (#1652), everything possible should be compressed before
>> sending over the wire...
>> Martin Morrison
>> Roanoke, VA  24018
>> 540.345.1410
>> gis.edsi.com
>> Spitzer
>> Sent: Monday, May 30, 2011 1:37 AM
>> Subject: Re: [mapguide-internals] Mapguide roadmap
>> Two performance improvement I'd like to see in 2.2.1
>> http://trac.osgeo.org/mapguide/ticket/1652 (gzip for mapagent)
>> Studio requests the describe schema xml multiple times and for
>> a larger schema it be can up over 1.5mb in size
>> http://trac.osgeo.org/mapguide/ticket/462 (GDAL connection opening
>> improvements, 10x win)
>> Two bug fixes which I'd like to nominate are
>> http://trac.osgeo.org/mapguide/ticket/1705 (truncated large WFS responses
>> and memory leak)
>> http://trac.osgeo.org/mapguide/ticket/1705 (webserver crash on parsing
>> invalid characters in numeric params)
>> On Sat, May 28, 2011 at 3:40 AM, Martin Morrison
>> <martin.morrison at edsi.com>wrote:
>>> Needs to be in 2.2.1
>>> http://trac.osgeo.org/mapguide/ticket/1682
>>> Martin Morrison
>>> Roanoke, VA  24018
>>> 540.345.1410
>>> gis.edsi.com
>>> <stuff deleted>
>>> What would you like fixed in MapGuide 2.2.1?
>>> <more stuff deleted>
>>> mapguide-internals mailing list
>>> mapguide-internals at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
>> Zac Spitzer
>> Solution Architect / Director
>> Ennoble Consultancy Australia
>> http://www.ennoble.com.au
>> http://zacster.blogspot.com
>> +61 405 847 168
Zac Spitzer
+61 405 847 168
More information about the mapguide-internals mailing list
