[mapguide-internals] Re: RFC 113 - Support Path Scaling In
Symbol Definition is ready for review
Aleck Sun
Aleck.Sun at autodesk.com
Tue Jun 14 04:06:27 EDT 2011
I have updated this RFC accordingly. The proposed milestone is now 2.4 and all the schema version is updated to 2.4.0.
Is there any other comments?
Thanks,
Aleck
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Bruce Dechant
Sent: Friday, June 10, 2011 1:20 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Re: RFC 113 - Support Path Scaling In Symbol Definition is ready for review
Makes sense.
Bruce
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Thursday, June 09, 2011 9:55 PM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] Re: RFC 113 - Support Path Scaling In Symbol Definition is ready for review
Well let's use Maestro as an example.
Maestro uses the [major].[minor] component of the Site version returned by the MapGuide as a way of determining what it is the set of resources (and their schema versions) is safe to work with.
Introducing this for the 2.3 OS version (which I assume returns 2.3 as the site version) and AIMS 2013 (which I assume will be > 2.3 in terms of site
version) throws a monkey wrench into client applications that use this kind of version checking logic.
Not to mention that there is no solid time-frames currently for when 2.3 is going to be released, and without solid community funding for build infrastructure (still a major problem), we cannot expect OS releases to consistently be in sync with the commercial ones.
Hence my concern about the milestone. Push the proposed milestone to 2.4 and this is not an issue.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/RFC-113-Support-Path-Scaling-In-Symbol-Definition-is-ready-for-review-tp6460741p6460820.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
