[mapguide-internals] Re: RFC 113 - Support Path Scaling In Symbol
Definition is ready for review
Zac Spitzer
zac.spitzer at gmail.com
Wed Jun 15 03:51:11 EDT 2011
is there anyway to enable/allow xml comments to be persisted in the file?
Symbols def's can be rather complex/tricky and not being able to
annotate the xml with comments makes it even harder to manage.
is there a limitation in dbxml?
z
On Tue, Jun 14, 2011 at 6:06 PM, Aleck Sun <Aleck.Sun at autodesk.com> wrote:
> I have updated this RFC accordingly. The proposed milestone is now 2.4 and all the schema version is updated to 2.4.0.
> Is there any other comments?
> Thanks,
> Aleck
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Bruce Dechant
> Sent: Friday, June 10, 2011 1:20 PM
> To: MapGuide Internals Mail List
> Subject: RE: [mapguide-internals] Re: RFC 113 - Support Path Scaling In Symbol Definition is ready for review
> Makes sense.
> Bruce
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> Sent: Thursday, June 09, 2011 9:55 PM
> To: mapguide-internals at lists.osgeo.org
> Subject: [mapguide-internals] Re: RFC 113 - Support Path Scaling In Symbol Definition is ready for review
> Well let's use Maestro as an example.
> Maestro uses the [major].[minor] component of the Site version returned by the MapGuide as a way of determining what it is the set of resources (and their schema versions) is safe to work with.
> Introducing this for the 2.3 OS version (which I assume returns 2.3 as the site version) and AIMS 2013 (which I assume will be > 2.3 in terms of site
> version) throws a monkey wrench into client applications that use this kind of version checking logic.
> Not to mention that there is no solid time-frames currently for when 2.3 is going to be released, and without solid community funding for build infrastructure (still a major problem), we cannot expect OS releases to consistently be in sync with the commercial ones.
> Hence my concern about the milestone. Push the proposed milestone to 2.4 and this is not an issue.
> - Jackie
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/RFC-113-Support-Path-Scaling-In-Symbol-Definition-is-ready-for-review-tp6460741p6460820.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
