[mapguide-internals] Re: Maestro 3.1.0 vs MagGuide trunk Rev 5924
UV uvwild at googlemail.com
Thu Jun 16 09:30:09 EDT 2011
I was building trunk debug from this revision and installed it to the
default osgeo location. \program files\osgeo\mapguide\....
I changed the php.ini and httpd.conf to use my debug libs.
I have done this before a few times and it worked.
However, I cannot connect with either maestro, or mapadmin, or my testapp.
Mapadmin says wrong password.
Testapp crashes with a mginitializewebtier('../webconfig.in...')
Maestro says:
Failed to log on because: Failed to connect, please check network
connection and login information.
Extended error info:
     The underlying connection was closed: An unexpected error occured
on a receive.
     Unable to read data from the transport connection: An existing
connection was forciblly closed by the remote host.
it seems the apache worker simply crashed:
apache error.log>>>>This application has requested the Runtime to
terminate it in an unusual way.
But where do I go from here or how do I get more information when the
logs are empty?
On 16/06/2011 12:55, Jackie Ng wrote:
> What connection problems in particular?
> I have had no issues connecting to a trunk build with Maestro 3.1
> - Jackie
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Maestro-3-1-0-vs-MagGuide-trunk-Rev-5924-tp6482458p6482551.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
