[mapguide-internals] Problem with WebTier in trunk build - wrong
handlername shows up in apache module - wrong httpd.conf????
UV
uvwild at googlemail.com
Thu Jun 16 11:03:53 EDT 2011
Hello,
I managed to put the debugger on the webtier and put a breakpoint in the
static int mgmapagent_handler (request_rec *r) method.
if (strcmp(r->handler, "mgmapagent_handler") != 0) // NOXLATE
Now the funny thing is that a request from the mapadmin to the apache
server show up as a
+ r->handler 0x00dc0e88 "application/x-httpd-php" const char *
value
which leads into DECLINED from:
return DECLINED;
so somewhere the request configuration is wrong. I am no longer
surprised that my config is not doing anything.
However, this is way out of my expertise. I find those strings in the
httpd.conf but did not touch them......
Anyone got some ideas?
More information about the mapguide-internals
