[mapguide-internals] WMS: OgcWmsService.config.awd is not reparsed until httpd restart
Gabriele Monfardini
gabrimonfa at gmail.com
Mon Aug 20 08:27:20 PDT 2012
Hi all,
I'm using Mapguide 2.4 with apache and php under centos.
I've modified OgcWmsService.config.awd a couple of times to specify
the correct ServerName, Title and so on.
The first time by mistake I wrote the wrong IP, let's say "a.b.c.d".
After a while I corrected the IP in, let's say, "x.y.z.t".
Always without restarting apache, but restarting Mapguide.
Querying GetCapabilities multiple times (for instance keep pressing
the F5 key) in a browser the GetMap URL sometimes says
localhost:8008 (the default URL, in the stock file)
some other times
a.b.c.d:8008 (the wrong URL, that was saved once in the file and then
overwritten)
and some other times
x.y.z.t:8008 (the correct URL, saved in the current version of the file)
confusing a lot WMS client and leading to very different outcome for my tests.
In particular I suppose that different threads read different cached
version of the file, very puzzling.
Restarting apache solves the problem.
Where is the information cached?
Regards,
Gabriele Monfardini
More information about the mapguide-internals
