[mapguide-internals] Re: Upgrade to VC10 and GDAL 1.9
Jackie Ng jumpinjackie at gmail.com
Thu Feb 2 07:50:02 EST 2012
A little update on my tale of getting VC10-compatible binaries.
I was able to successfully build Apache from source for both x86/x64, so far
so good.
PHP is a whole different story and I am roadblocked at this point. The
binaries under Oem\php does not seem to constitute a functional PHP
distribution. Compare the file listings to the binary release of PHP 5.3.8
and you will see that it is missing a whole lot of dlls which I presume to
be the compiled set of the prerequisite libraries needed by PHP (zlib,
libiconv, libxml2, icu) as described here:
https://wiki.php.net/internals/windows/libs#third_party_libraries
So I tried in vain to build these from source:
 * icu - VS2005 sln was provided, converted to VS2010 and built without
issues
 * zlib - No problems
 * libiconv - No msvc makefiles. No sln/vcproj files. Win32 build
instructions only covers cygwin/mingw which is not acceptable!
 * libxml2 - Depends on libiconv, so I can't build this either.
I'm starting to think moving to VC10 is becoming a bad idea. We need VC10
web component binaries and I just cannot build all the required bits from
scratch!
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Upgrade-to-VC10-and-GDAL-1-9-tp4337041p4358916.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
