[mapguide-internals] Re: Upgrade to VC10 and GDAL 1.9
Trevor Wekel trevor_wekel at otxsystems.com
Tue Jan 24 21:51:11 EST 2012
Hi Jackie,
Maybe Mars or Arthur can provide some insight?  I assume Autodesk must be maintaining 64 bit VC10 Apache binaries in their internal tree.
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc121
http://trac.osgeo.org/mapguide/ticket/1818
For the build.bat/build64.bat is msbuild.exe available under a pure VC10 environment?
Regards,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: January 24, 2012 7:42 PM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] Re: Upgrade to VC10 and GDAL 1.9
Hi Trevor,
By moving to VC10, we would need VC10 binaries of:
 - Apache
 - PHP
 - mod_jk.so
In both x86 and x64 flavours.
I noticed there's already a set of PHP windows binaries already checked into
Oem\Php. Not sure if these are VC10 compiled. x64 binaries appears to be
(depends show linkage to msvcr100). x86 binaries doesn't seem to be (depends
show linkage to msvcr90)
I cannot find VC10 apache binaries anywhere (ApacheLounge, my usual port of
call, does not offer VC10 apache builds). I have mixed success building
these components from source, and this was just with the VC9 compiler.
The installer itself is not a big deal. Just a case of updating lots of file
references.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Upgrade-to-VC10-and-GDAL-1-9-tp4337041p4337086.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
