[mapguide-internals] Re: Upgrade to VC10 and GDAL 1.9
Jackie Ng jumpinjackie at gmail.com
Tue Jan 24 22:24:15 EST 2012
Hi Trevor,
build.bat/build64.bat uses whatever msbuild is defined by the env vars. So
if you run this from a VS2010 command prompt, it should use the v4.0
msbuild.exe calling into the VC10 compiler.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Upgrade-to-VC10-and-GDAL-1-9-tp4337041p4337119.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
