[mapguide-internals] RE: IPv6 support mandatory?
Mars Wu
mars.wu at autodesk.com
Fri Mar 16 01:46:08 EDT 2012
Hi all,
Sorry for getting back for this so late. It turns out another pre-directive has to be defined to make ACE work on a platform without IPv6 installed.
A ticket and patch has been created here: http://trac.osgeo.org/mapguide/ticket/1975
Thanks,
Mars
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Friday, December 02, 2011 10:53 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] RE: IPv6 support mandatory?
any luck with this? we ran into some other issues after enabling ipv6 on a 2003 server
On Tue, Sep 13, 2011 at 1:12 PM, Mars Wu <mars.wu at autodesk.com> wrote:
> Hi Jackie,
> Then that's a little bit strange. I have to debug to see what's the problem. I will let you know the result.
> Thanks,
> Mars
> Jackie Ng
> Sent: Tuesday, September 13, 2011 11:11 AM
> To: mapguide-internals at lists.osgeo.org
> Subject: [mapguide-internals] RE: IPv6 support mandatory?
> Hi Mars,
> The IP address that I had in the serverconfig.ini was just the IPv4 loopback (ie. 127.0.0.1).
> - Jackie
> http://osgeo-org.1803224.n2.nabble.com/IPv6-support-mandatory-tp678233
> 5p6786045.html Sent from the MapGuide Internals mailing list archive
> at Nabble.com.
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
