[mapguide-internals] Blocking issue in Mapguide 2.4
Bruno Scott
bscott at geomapgis.com
Tue Feb 19 06:06:40 PST 2013
Hi jackie
Your test case seems to be good, it's pretty much the same as what i'm doing
here.
But it only test service->UpdateFeatures
The problem i have is in OpUpdateFeatures.cpp, one level higher.
void MgOpUpdateFeatures::Execute()
*/ //this is the thing unittest is testing/*
Ptr<MgPropertyCollection> rowsAffected =
m_service->UpdateFeatures(resource, commands,...
* / //here the ticket fix #649/*
* / //and finally this is the place where something gets wrong/*
if (mgException != NULL || !partialFailureMsg.empty())
MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Failure.c_str());
if (mgException == NULL && !partialFailureMsg.empty())
MgStringCollection args;
args.Add(partialFailureMsg);
mgException = new
MgFeatureServiceException(L"MgOpUpdateFeatures.Execute",...
MG_LOG_OPERATION_MESSAGE_ACCESS_ENTRY();
MG_FEATURE_SERVICE_THROW()
View this message in context: http://osgeo-org.1560.n6.nabble.com/Blocking-issue-in-Mapguide-2-4-tp5034831p5035200.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
