[mapguide-internals] Blocking issue in Mapguide 2.4
Walt Welton-Lair
walt.welton-lair at autodesk.com
Tue Feb 19 10:26:22 PST 2013
I took a quick look and the fix looks reasonable.
Old behavior: If a partial failure is detected the code writes a normal response (via call to EndExecution, which sets m_opCompleted to true) AND throws an exception (which I believe writes another response).
New behavior: If a partial failure is detected the code no longer writes a normal response and will instead JUST throw the exception.
Your changes are to code that Jackie added when fixing ticket 649, so Jackie should also review your fix. And of course also verify that the unit test Jackie added to the ticket will pass with your fix.
Walt
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Bruno Scott
Sent: Tuesday, February 19, 2013 9:43 AM
To: mapguide-internals at lists.osgeo.org
Subject: Re: [mapguide-internals] Blocking issue in Mapguide 2.4
I think i found the real problem.
Patch on the ticket is updated
Bruno
View this message in context: http://osgeo-org.1560.n6.nabble.com/Blocking-issue-in-Mapguide-2-4-tp5034831p5035216.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
