Hi Jackie, I assumed that the current XYZ Tile Set are supported at a higher-up application level (FusionSF.js). Therefore, if this is doable on the same level, it will be nice. Thanks, Reno -- Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Internals-f4209935.html
