[mapguide-internals] Fwd: Problems to Build MapGuide OpenSource 3.1.2 and FDO 4.0.0 for CentOS 6 and 7 with 64 bits
Luiz Marcio Viana
luiz.marcio.viana at globo.com
Fri Jan 15 06:44:29 PST 2021
Hello Jackie,
How are you?
I'm now compiling the MapGuide OpenSource 3.1 with FDO 4.1 from the svn
branch on a CentOS 6 32 bits, and that version is fine.
I think the problems occour because I was building MapGuide OpenSource
from the trunk.
Could you schedule a meeting at next monday (January 16th) at 10 a.m.
(San Rafael - California pacific date time - 16 p.m. at Copacabana - Rio
de Janeiro)?
Thanks,
Luiz Marcio Faria de Aquino Viana, M.Sc.
TLMV Consultoria e Sistemas EIRELI
http://www.tlmv.com.br
+55-21-99983-7207
Em 1/14/21 9:56 PM, Luiz Marcio Viana escreveu:
> Hello Jackie,
> How are you?
> I think I could help you with the Java problem, the MapGuideApi.jar is
> just an JNI application wich automaticly generated by SWIG.
> Another think, how can I directly contact you, using Google Meeting or
> Phone Call.
> NOTE: I don't use WhatsApp or other Social Network.
> Thanks,
> +55-21-99983-7207
> -------- Mensagem encaminhada --------
> Assunto: Problems to Build MapGuide OpenSource 3.1.2 and FDO 4.0.0
> Data: Thu, 14 Jan 2021 18:28:04 -0300
> De: Luiz Marcio Viana <luiz.marcio.viana at globo.com>
> Para: Jackie Ng <jumpinjackie at gmail.com>,
> mapguide-internals at lists.osgeo.org
> CC: lmarcio at tlmv.com.br, luiz.marcio.viana at globo.com,
> luiz.marcio.viana at gmail.com
> Hello Jackie,
> How are you?
> I have used MapGuide OpenSource since the first versions, and I have
> identified some problems to compile that software from the source code
> after the release 2.5.
> Some problems take the activity of compile the MapGuide OpenSource
> 3.1.2 with FDO 4.0.0 on a CentOS 6 or 7 with 64 bits a task dificult
> to execute.
> I have also identified some problems with the compilation script when
> I build the software for CentOS 6 32 bits.
> SUGESTION: In the past, the final source code used to build the
> MapGuide OpenSource releases was available for download.
> Thanks,
> +55-21-99983-7207
> Em 10/15/20 6:18 AM, Jackie Ng escreveu:
>> Hi All,
>> I've put up the second preview release of MapGuide Open Source 4.0
>> https://trac.osgeo.org/mapguide/wiki/Release/4.0.0/Preview2/Notes
>> This release is for *testing purposes* and use in a production
>> environment
>> is not encouraged.
>> Preview 2 finally includes the Linux build that was missing from the
>> previous preview release. One important note for our Linux users is that
>> our Linux build of MapGuide now only targets Ubuntu 16.04 LTS 64-bit and
>> that Java support is currently broken on Linux.
>> We recently upgraded our bundled Tomcat to the 9.x series and
>> required some
>> config changes. Java support works on Windows, but is failing on
>> Linux and
>> we lack the proper resources to debug and investigate further. All we
>> know
>> and suspect so far is that it is some missing security-related
>> configuration needed since Tomcat 8 or 9, but we don't know what that
>> missing configuration is and as a result all our .jsp requests cause
>> Tomcat
>> to return HTTP 403 forbidden errors, rendering our Java viewer and
>> associated code samples to not work out of the box.
>> If any of you have any idea what the problem is (by installing the
>> preview
>> 2 Linux build into your spare Ubuntu 16.04 VM or docker container and
>> mess
>> with the existing configuration to get the Java viewer into a working
>> state), please let us know of your findings in this trac issue (
>> https://trac.osgeo.org/mapguide/ticket/2828) or by posting your
>> findings to
>> the mapguide-users mailing list.
>> I will be resuming the MapGuide 4.0 new feature blog series shortly as
>> there are still many new features to be covered.
>> - Jackie
>> mapguide-internals mailing list
>> https://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
