[mapguide-internals] Fwd: Problems to Build MapGuide OpenSource 3.1.2 and FDO 4.0.0 for CentOS 6 and 7 with 64 bits
Luiz Marcio Viana luiz.marcio.viana at globo.com
Fri Jan 15 12:54:30 PST 2021
Hello Jackie,
Could you confirm the meeting at next monday (January 18th) at 10 a.m.
(San Rafael - California pacific date time)?
Thanks,
Luiz Marcio Faria de Aquino Viana, M.Sc.
TLMV Consultoria e Sistemas EIRELI
http://www.tlmv.com.br
+55-21-99983-7207
Em 1/15/21 11:44 AM, Luiz Marcio Viana escreveu:
> Hello Jackie,
> How are you?
> I'm now compiling the MapGuide OpenSource 3.1 with FDO 4.1 from the
> svn branch on a CentOS 6 32 bits, and that version is fine.
> I think the problems occour because I was building MapGuide OpenSource
> from the trunk.
> Could you schedule a meeting at next monday (January 16th) at 10 a.m.
> (San Rafael - California pacific date time - 16 p.m. at Copacabana -
> Rio de Janeiro)?
> Thanks,
> +55-21-99983-7207
> Em 1/14/21 9:56 PM, Luiz Marcio Viana escreveu:
>> Hello Jackie,
>> How are you?
>> I think I could help you with the Java problem, the MapGuideApi.jar
>> is just an JNI application wich automaticly generated by SWIG.
>> Another think, how can I directly contact you, using Google Meeting
>> or Phone Call.
>> NOTE: I don't use WhatsApp or other Social Network.
>> Thanks,
>> +55-21-99983-7207
>> -------- Mensagem encaminhada --------
>> Assunto: 	Problems to Build MapGuide OpenSource 3.1.2 and FDO 4.0.0
>> Data: 	Thu, 14 Jan 2021 18:28:04 -0300
>> De: 	Luiz Marcio Viana <luiz.marcio.viana at globo.com>
>> Para: 	Jackie Ng <jumpinjackie at gmail.com>,
>> mapguide-internals at lists.osgeo.org
>> CC: 	lmarcio at tlmv.com.br, luiz.marcio.viana at globo.com,
>> luiz.marcio.viana at gmail.com
>> Hello Jackie,
>> How are you?
>> I have used MapGuide OpenSource since the first versions, and I have
>> identified some problems to compile that software from the source
>> code after the  release 2.5.
>> Some problems take the activity of compile the MapGuide OpenSource
>> 3.1.2 with FDO 4.0.0 on a CentOS 6 or 7 with 64 bits a task dificult
>> to execute.
>> I have also identified some problems with the compilation script when
>> I build the software for CentOS 6 32 bits.
>> SUGESTION: In the past, the final source code used to build the
>> MapGuide OpenSource releases was available for download.
>> Thanks,
>> +55-21-99983-7207
>> Em 10/15/20 6:18 AM, Jackie Ng escreveu:
>>> Hi All,
>>> I've put up the second preview release of MapGuide Open Source 4.0
>>> https://trac.osgeo.org/mapguide/wiki/Release/4.0.0/Preview2/Notes
>>> This release is for *testing purposes* and use in a production
>>> environment
>>> is not encouraged.
>>> Preview 2 finally includes the Linux build that was missing from the
>>> previous preview release. One important note for our Linux users is that
>>> our Linux build of MapGuide now only targets Ubuntu 16.04 LTS 64-bit and
>>> that Java support is currently broken on Linux.
>>> We recently upgraded our bundled Tomcat to the 9.x series and
>>> required some
>>> config changes. Java support works on Windows, but is failing on
>>> Linux and
>>> we lack the proper resources to debug and investigate further. All
>>> we know
>>> and suspect so far is that it is some missing security-related
>>> configuration needed since Tomcat 8 or 9, but we don't know what that
>>> missing configuration is and as a result all our .jsp requests cause
>>> Tomcat
>>> to return HTTP 403 forbidden errors, rendering our Java viewer and
>>> associated code samples to not work out of the box.
>>> If any of you have any idea what the problem is (by installing the
>>> preview
>>> 2 Linux build into your spare Ubuntu 16.04 VM or docker container
>>> and mess
>>> with the existing configuration to get the Java viewer into a working
>>> state), please let us know of your findings in this trac issue (
>>> https://trac.osgeo.org/mapguide/ticket/2828) or by posting your
>>> findings to
>>> the mapguide-users mailing list.
>>> I will be resuming the MapGuide 4.0 new feature blog series shortly as
>>> there are still many new features to be covered.
>>> - Jackie
>>> mapguide-internals mailing list
>>> https://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
