[mapguide-internals] Fwd: Problems to Build MapGuide OpenSource 3.1.2 and FDO 4.0.0 for CentOS 6 and 7 with 64 bits
Luiz Marcio Viana
luiz.marcio.viana at globo.com
Sat Jan 16 03:14:54 PST 2021
Hello Jackie,
How are you?
It's nice to know you are in this great country... Australia!!!
How can I contact you directly?
Um abração,
Luiz Marcio Faria de Aquino Viana, M.Sc.
TLMV Consultoria e Sistemas EIRELI
http://www.tlmv.com.br
+55-21-99983-7207
Em 1/15/21 5:54 PM, Luiz Marcio Viana escreveu:
> Hello Jackie,
> Could you confirm the meeting at next monday (January 18th) at 10 a.m.
> (San Rafael - California pacific date time)?
> Thanks,
> +55-21-99983-7207
> Em 1/15/21 11:44 AM, Luiz Marcio Viana escreveu:
>> Hello Jackie,
>> How are you?
>> I'm now compiling the MapGuide OpenSource 3.1 with FDO 4.1 from the
>> svn branch on a CentOS 6 32 bits, and that version is fine.
>> I think the problems occour because I was building MapGuide
>> OpenSource from the trunk.
>> Could you schedule a meeting at next monday (January 16th) at 10 a.m.
>> (San Rafael - California pacific date time - 16 p.m. at Copacabana -
>> Rio de Janeiro)?
>> Thanks,
>> +55-21-99983-7207
>> Em 1/14/21 9:56 PM, Luiz Marcio Viana escreveu:
>>> Hello Jackie,
>>> How are you?
>>> I think I could help you with the Java problem, the MapGuideApi.jar
>>> is just an JNI application wich automaticly generated by SWIG.
>>> Another think, how can I directly contact you, using Google Meeting
>>> or Phone Call.
>>> NOTE: I don't use WhatsApp or other Social Network.
>>> Thanks,
>>> +55-21-99983-7207
>>> -------- Mensagem encaminhada --------
>>> Assunto: Problems to Build MapGuide OpenSource 3.1.2 and FDO 4.0.0
>>> Data: Thu, 14 Jan 2021 18:28:04 -0300
>>> De: Luiz Marcio Viana <luiz.marcio.viana at globo.com>
>>> Para: Jackie Ng <jumpinjackie at gmail.com>,
>>> mapguide-internals at lists.osgeo.org
>>> CC: lmarcio at tlmv.com.br, luiz.marcio.viana at globo.com,
>>> luiz.marcio.viana at gmail.com
>>> Hello Jackie,
>>> How are you?
>>> I have used MapGuide OpenSource since the first versions, and I have
>>> identified some problems to compile that software from the source
>>> code after the release 2.5.
>>> Some problems take the activity of compile the MapGuide OpenSource
>>> 3.1.2 with FDO 4.0.0 on a CentOS 6 or 7 with 64 bits a task dificult
>>> to execute.
>>> I have also identified some problems with the compilation script
>>> when I build the software for CentOS 6 32 bits.
>>> SUGESTION: In the past, the final source code used to build the
>>> MapGuide OpenSource releases was available for download.
>>> Thanks,
>>> +55-21-99983-7207
>>> Em 10/15/20 6:18 AM, Jackie Ng escreveu:
>>>> Hi All,
>>>> I've put up the second preview release of MapGuide Open Source 4.0
>>>> https://trac.osgeo.org/mapguide/wiki/Release/4.0.0/Preview2/Notes
>>>> This release is for *testing purposes* and use in a production
>>>> environment
>>>> is not encouraged.
>>>> Preview 2 finally includes the Linux build that was missing from the
>>>> previous preview release. One important note for our Linux users is
>>>> that
>>>> our Linux build of MapGuide now only targets Ubuntu 16.04 LTS
>>>> 64-bit and
>>>> that Java support is currently broken on Linux.
>>>> We recently upgraded our bundled Tomcat to the 9.x series and
>>>> required some
>>>> config changes. Java support works on Windows, but is failing on
>>>> Linux and
>>>> we lack the proper resources to debug and investigate further. All
>>>> we know
>>>> and suspect so far is that it is some missing security-related
>>>> configuration needed since Tomcat 8 or 9, but we don't know what that
>>>> missing configuration is and as a result all our .jsp requests
>>>> cause Tomcat
>>>> to return HTTP 403 forbidden errors, rendering our Java viewer and
>>>> associated code samples to not work out of the box.
>>>> If any of you have any idea what the problem is (by installing the
>>>> preview
>>>> 2 Linux build into your spare Ubuntu 16.04 VM or docker container
>>>> and mess
>>>> with the existing configuration to get the Java viewer into a working
>>>> state), please let us know of your findings in this trac issue (
>>>> https://trac.osgeo.org/mapguide/ticket/2828) or by posting your
>>>> findings to
>>>> the mapguide-users mailing list.
>>>> I will be resuming the MapGuide 4.0 new feature blog series shortly as
>>>> there are still many new features to be covered.
>>>> - Jackie
>>>> _______________________________________________
>>>> mapguide-internals mailing list
>>>> https://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
