[mapguide-trac] #35: Error calling MgWktReaderWriter.Write from PHP
MapGuide Open Source trac_mapguide at osgeo.org
Thu Apr 5 05:59:47 EDT 2007
   Reporter:  waltweltonlair  |       Owner:
       Type:  defect          |      Status:  new
   Priority:  high            |   Milestone:  1.2
  Component:  Web API         |     Version:  1.2.0
   Severity:  major           |    Keywords:
External_id:                  |
 Reported by Jason Birch:
 This:
 [http://www.jasonbirch.com/temp/test.phps]
 Gives me errors either way I run it (UTM to LL or LL to UTM).
 Fatal error: Type error in argument 1 of !MgWktReaderWriter_Write.
 Expected _p_MgGeometry in C:\Program
 Files\!MapGuideOpenSource\!WebServerExtensions\Apache2\htdocs\parcels\test
 .php on line 42
 It works just fine if I remove the transform as the second optional
 parameter to the WKT reader.  The thing is that these same transforms
 are working correctly on features that I'm reading directly from a
 !FeatureSource.  So what am I missing?
 This is just a test case.  What I really want to do with the transformed
 bounding box is something like:
 $queryOptions->!SetSpatialFilter("Geometry", $bboxUTM10,
 MgFeatureSpatialOperations::!EnvelopeIntersects);
 I'm basically trying to take in a BBOX in LL, transform it to UTM10,
 then use its envelope as a spatial filter.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/35>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
