[mapguide-trac] #35: Error calling MgWktReaderWriter.Write from
PHP
trac_mapguide at osgeo.org
Thu Apr 5 06:07:18 EDT 2007
#35: Error calling MgWktReaderWriter.Write from PHP
Reporter: waltweltonlair | Owner:
Type: defect | Status: new
Priority: high | Milestone: 1.2
Component: Web API | Version: 1.2.0
Severity: major | Resolution:
Keywords: | External_id:
Comment (by waltweltonlair):
Paul Spencer also reported a similar problem:
Hi all,
In the API documentation, there are three potential signatures
for the generateplot function. It seems that the second signature
will not work in PHP due to an error in the swig bindings:
virtual !MgByteReader * !GeneratePlot (!MgMap *map,
!MgCoordinate *center, double scale,
!MgPlotSpecification *plotSpec,
!MgLayout *layout,
!MgDwfVersion *dwfVersion)
Calling this function results in a PHP Fatal error:
Arguments passed did not match any overload for method
_wrap_MgMappingService_GeneratePlot
The other signatures seem to work.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/35#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
