[mapguide-trac] #175: Unmanaged SHP File Locations Performance
Issues as More Files get Added
trac_mapguide at osgeo.org
Fri May 25 13:05:36 EDT 2007
#175: Unmanaged SHP File Locations Performance Issues as More Files get Added
Reporter: cgountanis | Owner:
Type: defect | Status: new
Priority: high | Milestone: 1.2
Component: Server | Version: 1.2.0
Severity: major | Keywords: fdo,mapguide 1.2 beta 2, shp, dbf
External_id: |
Why do unmanaged FeatureSources respond slower as more files get added to
the directory location? We have a FeatureSource called SHPDefualt for
example. The zooms take longer as well as other functions. It seems when
you query a Feature Source is does not hit the DBF you want directly it
seems to fiddle with everything in the unmanaged directory. We love the
concept of a folder that contains all SHP files. One location is great for
batch processes and great for editing new layers. It is just simple for
customers to understand. For sure easier to back up and recreate. Will
this always be a performance killer? Was testing on Windows 2000, XP and
Vista with same results using MGOS 1.2 B2 and FDO 3.2.2 B2.
Is this a bug? Will this be fixed soon?
This really takes the complication out of knowing what the heck is going
on in the repository. Here is XML Example:
<?xml version="1.0" encoding="utf-8" ?>
<FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
<Provider>OSGeo.SHP</Provider>
<Parameter>
<Name>DefaultFileLocation</Name>
<Value>C:\SHPFILES</Value>
</Parameter>
</FeatureSource>
Easy way to reproduce this would be create an unmanaged shp feature
source. Put one shp file with associated files and create a map. Goto the
web layout stage and make sure you test with something that queries
feature sources like zooms. Now add 20+ shp files the bigger the fdo the
slower it gets. Don't change the map or web layout. Do the same thing as
before run the site with the initial one layer and zoom. You should notice
a HUGE slow down compared to the single shp file as started off.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/175>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
