[mapguide-trac] #175: Unmanaged SHP File Locations Performance Issues as More Files get Added
MapGuide Open Source trac_mapguide at osgeo.org
Wed May 30 15:01:05 EDT 2007
 Reporter:  cgountanis                         |         Owner:
     Type:  defect                             |        Status:  new
 Priority:  high                               |     Milestone:  1.2
Component:  Server                             |       Version:  1.2.0
 Severity:  major                              |    Resolution:
 Keywords:  fdo,mapguide 1.2 beta 2, shp, dbf  |   External_id:
Comment (by tomfukushima):
 I tried this out and although I am seeing slowdown with 17 SHP files (200
 MB worth of data).  It is still very reasonable.  The 17
 Any help that you can provide in pinpointing this problem would be useful.
 For example, what particular thing with SHPs in a single directory causes
 the problem (since I'm not seeing the same problem).  Also, does turning
 connection pooling on for SHP fix the problems?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/175#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
