[mapguide-trac] #323: Perpetual spatial queries drain
Autodesk.SqlServer FDO provider connection pool: .NET API
trac_mapguide at osgeo.org
Wed Nov 21 05:04:54 EST 2007
#323: Perpetual spatial queries drain Autodesk.SqlServer FDO provider connection
pool: .NET API
Reporter: MaksimS | Owner:
Type: defect | Status: new
Priority: medium | Milestone:
Component: Feature Service | Version: 1.2.0
Severity: major | Keywords:
External_id: |
MapGuide Enterprise 2008 / Microsoft SQL Server 2005 / Windows 2003 Server
Issuing perpetual calls to managed FeatureService.SelectFeatures using
spatial query causes MapGuide to drain Autodesk.SqlServer FDO provider
connection pool. Exception being thrown:
OSGeo.MapGuide.MgApplicationException: Cannot create any more connections
to the Autodesk.SqlServer FDO provider.
- MgFeatureServiceHandler.ProcessOperation line 83 file
c:\build_bond_area\bond_nightly\build_41.3\ent\os\server\src\services\feature\FeatureServiceHandler.cpp
- MgOpSelectFeatures.Execute line 112 file
c:\build_bond_area\bond_nightly\build_41.3\ent\os\server\src\services\feature\OpSelectFeatures.cpp
- MgServerSelectFeatures.SelectFeatures line 243 file
c:\build_bond_area\bond_nightly\build_41.3\ent\os\server\src\services\feature\ServerSelectFeatures.cpp
- MgFdoConnectionManager.Open line 256 file
c:\build_bond_area\Bond_Nightly\BUILD_41.3\Ent\OS\Server\src\Common\Manager\FdoConnectionManager.cpp
Spatial query calls are running on the same MapGuide session. It seems
that MapGuide opens a new SQL Server session on each spatial query and
keeps it open for a while, long enough to fill the session pool.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/323>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
