[mapguide-trac] #230: Polygon features randomly appear and
disappear
trac_mapguide at osgeo.org
Wed Nov 21 12:40:52 EST 2007
#230: Polygon features randomly appear and disappear
Reporter: jng | Owner:
Type: defect | Status: reopened
Priority: high | Milestone:
Component: General | Version: 1.2.0
Severity: critical | Resolution:
Keywords: | External_id:
Changes (by mmicall):
* status: closed => reopened
* resolution: invalid =>
Comment:
I am using a straight polygon shapefile joined with an access odbc
connection to a table within the database. The information is themed
against one of the resultant joined fields.
When I am zoomed out - some of the records display with the correct symbol
- when I zoom right in on a polygon it may or may not switch to another
colour and if I pan and I am zoomed in really close it might display the
proper classification symbol.
Seems similar as above issue - only using a shapefile.
I did notice that the field definition of the schema for the shapefile and
the access table are different within ArcMap (used to review data). In
the fields tab of the layer properties form, the precision and length are
different for the joining fields.
I have tried to make them the same but was unable.
First time posting - advanced apologies!
Mike Micallef
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/230#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
