[mapguide-trac] #327: add ability to modify 'ratio' on singleTile layers through ApplicationDefinition
MapGuide Open Source trac_mapguide at osgeo.org
Thu Nov 22 13:08:56 EST 2007
 Reporter:  pagameba  |         Owner:  madair at dmsolutions.ca
     Type:  defect    |        Status:  closed
 Priority:  medium    |     Milestone:  2.0
Component:  Fusion    |       Version:
 Severity:  minor     |    Resolution:  fixed
 Keywords:            |   External_id:
Changes (by madair):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 already implemented with the MapRatio extension in the MapGroup -> Map
 object in AppDef.xml.  The default value is set to 1.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/327#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
