[mapguide-trac] #328: Fusion: error property in JSON object of
mapLoaded is incomplete.
trac_mapguide at osgeo.org
Thu Nov 22 18:47:26 EST 2007
#328: Fusion: error property in JSON object of mapLoaded is incomplete.
Reporter: jng | Owner:
Type: defect | Status: new
Priority: medium | Milestone:
Component: General | Version:
Severity: major | Keywords:
External_id: |
I've tried creating an ApplicationDefinition (Slate) out of one of our
existing cemetery maps to see what it looked. When I loaded the map, it
gave me this error
Fusion Error: Missing } in property list at /fusion/mapguide/MapGuide.js
(line 193)
So I looked at that particular line in firebug, and it was a json object
being eval'ed, so I reloaded the map again so I could trap the json
output, and this is what I got from firebug (copy/pasted)
{sessionId:'0f952198-0000-1000-8003-
000c292b5017_en_0A00053B0AFC0AFB0AFA',mapId:'Library://Cemeteries/Bridgewater/Maps/BridgewaterMap.MapDefinition',metersPerUnit:1,mapName:'BridgewaterMap',extent:[226822.35112645,5943821.3474294,227164.83574661,5944235.9071711],layers:[{propertyMappings:{},uniqueId:'
1163a9cc-0000-1000-8005-
000c292b5017',layerName:'TreePoints',layerTypes:[0],displayInLegend:true,expandInLegend:true,resourceId:'Library://Cemeteries/Bridgewater/Layers/TreePoints.LayerDefinition',parentGroup:'
1163a9cc-0000-1000-8003-
000c292b5017',legendLabel:'TreePoints',selectable:true,visible:true,actuallyVisible:false,editable:true,scaleRanges:
[{minScale:1501,maxScale:100000000.0,styles:[{legendLabel:'',filter:'',geometryType:1,categoryIndex:0}]},{minScale:901,maxScale:1500,styles:[{legendLabel:'',filter:'',geometryType:1,categoryIndex:0}]},{minScale:361,maxScale:900,styles:[{legendLabel:'',filter:'',geometryType:1,categoryIndex:0}]},{minScale:100,maxScale:360,styles:[{legendLabel:'',filter:'',geometryType:1,categoryIndex:0}]}]},{propertyMappings:{},uniqueId:'
1163a9cc-0000-1000-8006-
000c292b5017',layerName:'MainTitle',layerTypes:[0],displayInLegend:true,expandInLegend:true,resourceId:'Library://Cemeteries/Bridgewater/Layers/MainTitle.LayerDefinition',parentGroup:'
1163a9cc-0000-1000-8004-
000c292b5017',legendLabel:'MainTitle',selectable:false,visible:true,actuallyVisible:true,editable:true,scaleRanges:
[{minScale:0,maxScale:100000000.0,styles:[{legendLabel:'',filter:'',geometryType:1,categoryIndex:0}]}]},{ERROR:
An exception occurred in FDO component.
RDBMS: No current open database.
Exception occurred in method MgFdoConnectionManager.Open at line 862 in
file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_10.7\mgdev\server\src\common\manager\FdoConnectionManager.cpp
- MgFeatureServiceHandler.ProcessOperation line 83 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_10.7\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
- MgOpGetClassDefinition.Execute line 157 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_10.7\mgdev\server\src\services\feature\OpGetClassDefinition.cpp
- MgServerDescribeSchema.GetClassDefinition line 1443 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_10.7\mgdev\server\src\services\feature\ServerDescribeSchema.cpp
- MgServerDescribeSchema.DescribeSchema line 538 file
- MgServerDescribeSchema.ExecuteDescribeSchema line 171 file
- MgFdoConnectionManager.Open line 862 file
The short answer is:
- At least one of the layers was broken because it was linked to a
database that didn't exist on our test machine. The old AJAX viewer
would've gracefully handled it by simply not rendering that particular
layer.
- The json output above is missing two } characters
1 - At the end of the error property of the json object
2 - At the end of the json object.
Could the MapGuide stack trace be interfering with the JSON output?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/328>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
