[mapguide-trac] #337: Bad GETMAPIMAGE parameter causes IIS worker
process pool to die
trac_mapguide at osgeo.org
Fri Nov 23 15:56:04 EST 2007
#337: Bad GETMAPIMAGE parameter causes IIS worker process pool to die
Reporter: jbirch | Owner:
Type: defect | Status: new
Priority: medium | Milestone:
Component: Map Agent | Version: 2.0.0
Severity: major | Keywords:
External_id: |
I was messing around swapping around parameters to see if I could get 8bit
PNG (yes I know it's not supported in GetMapImage) and found that entering
PNG8 into a GetMapImage call caused my IIS worker process to die, with an
error in the System Application log, but none in the MapGuide logs.
Here's a sample of the request I made:
http://localhost/mapguide/mapagent/mapagent.fcgi?session=3b5ee024-0000-
1000-8000-
000c293f205f_en_0A0A6EC10AFC0AFB0AFA&mapname=Sheboygan&operation=GETMAPIMAGE&format=PNG8&version=1.0.0&ts=1195850858076&locale=en&setdisplaydpi=96&setdisplayheight=1128&setdisplaywidth=1882.5&setviewcenterx=-87.71854751863403&setviewcentery=43.75168236754095&setviewscale=7759.005619599771
This kind of call should not be allowed to fail in a way that causes what
is essentially a DOS vector.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/337>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
