[mapguide-trac] #644: Problem with "building the WebServer"
MapGuide Open Source trac_mapguide at osgeo.org
Fri Aug 1 07:22:50 EDT 2008
 Reporter:  ssnc          |         Owner:
     Type:  defect        |        Status:  new
 Priority:  high          |     Milestone:
Component:  Build System  |       Version:  2.0.1
 Severity:  blocker       |    Resolution:
 Keywords:                |   External_id:  ssnc
Changes (by ssnc):
  * summary:  Problem with "building the Server" => Problem with "building
              the WebServer"
Comment:
 I have solved the "building the Server". Now, When I open the project
 WebInstallDir\src\WebTier.sln to "Building the Web
 Server Extensions", there are two projects, IsapiAgent.vcproj and
 MapAgentCommon.vcproj, who said they do not exist and it is true, the
 folder
 MapAgentCommon exits, but within the folder the file MapAgentCommon.vcproj
 does not exist and IsapiAgent.vcproj there isn´t neither the folder
 IsapiAgent
 (the files are not in the mapGuide.tar-2.0.1.2716.tar.gz). Does this
 influences when making the Building the Web Server Extensions?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/644#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
