[mapguide-trac] #667: Problem with mgserver.exe
MapGuide Open Source trac_mapguide at osgeo.org
Tue Aug 19 12:56:18 EDT 2008
   Reporter:  ssnc     |       Owner:
       Type:  task     |      Status:  new
   Priority:  high     |   Milestone:
  Component:  Server   |     Version:  2.0.1
   Severity:  blocker  |    Keywords:
External_id:           |
 Hello, I´m building the debug version on Windows Vista. I´m in the step
 "Verifying the Configuration"; I set command line arguments to allow the
 server to run interactively putting in the Command Arguments the word
 "run". I begin the debugging and when the server starts, the next occurs:
 see the file "Resultados-Depurar.txt" (results of the debugging) and see
 the two images. I made the debugging step by step and there are some
 errors:
 int ACE_TMAIN(int argc, ACE_TCHAR *argv[])
 _____________________________
 #ifdef WPRFLAG
             __winitenv = envp;
             mainret = wmain(argc, argv, envp);
 #else  /* WPRFLAG */
 __________________________________________________
 #endif  /* _WINMAIN_ */
              * Note that if the exe is managed app, we don't really need
 to
              * call exit or _c_exit. .cctor should be able to take care of
              * this.
             if ( !managedapp )
                 exit(mainret);
 Files with errors (inside the project "ServerCore") :
 ClientAcceptor.cpp
 main.cpp
 OperationThread.cpp
 Server.cpp
 ServerFactory.cpp
 ServiceHandlerFactory.cpp
 SignalHandler.cpp
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/667>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
