[mapguide-trac] #667: Problem with mgserver.exe
MapGuide Open Source trac_mapguide at osgeo.org
Tue Aug 19 15:58:26 EDT 2008
 Reporter:  ssnc     |         Owner:
     Type:  task     |        Status:  closed
 Priority:  high     |     Milestone:
Component:  Server   |       Version:  2.0.1
 Severity:  blocker  |    Resolution:  invalid
 Keywords:           |   External_id:
Changes (by tomfukushima):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 Hi, the first set of errors with the fonts can be ignored.  The
 mgserver2.jpg points to the problem which is that the FDO dlls cannot be
 found.  If you look in the serverconfig.ini file, you will see an FDOPath
 setting.  Make sure it is set to where the FDO DLLs are.
 I would say that for these types of configuration problems, to try to post
 the question to the mailing lists instead of creating tickets as this is
 not really a defect or enhancement.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/667#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
